Quote Originally Posted by bluEP3_SC View Post
Yes its linear- but it makes boost a lot quicker on the low cam before the crossover due to back pressure in the cylinder head ( smaller cam lobe= not as much flow)- once it crosses to the high cam boost drops 2-3 psi then continues to build linearly until redline.
What is your boost at redline?! I'm thinking you're at 12 psi that early on you must be at 20 psi? By redline?
