Results 1 to 5 of 5
Thread: D.I.Y Bumper Tab Fixing
    So I came up with an idea and so far it is working. Nothing is more frustrating and annoying then the famous broke bumper tabs!! :firemad::firemad::firemad:
    So I went and bought a new bigger soldering gun with a big flat tip designed for smoothing in mind
    Here is the really bad side you can see is completely broken...
    first step is remove the paint around the tab. I just melted it off. Now I'm using plastic I cut off from the bottom of the bumper where you can't see. This bumper is so cut up from the intercooler we'll never notice lol
    basically I just cut a slit of plastic and I'm going to use it like a solder stick!
    I start melting both side of the tabs and melting my stick of plastic
    Now it will look crazy at first!
    but we can keep melting it down and shaping it and forming it.
    You need to though take breaks and let the plastic reharden and form. Then keep melting it into shape
    I also on the other side melted over the hole so to fix that I use a nail
    then kept working around it
    but basically I just fused the plastic together and shaped it and smoothed it and kept the original shape as best as I could. Let it cool down and harden and you could feel the strength. We tested it out and taking it on and off it still breaks from pressure but once we put it on we went out driving and she never broke once.
    So if you plan on pulling your bumper all the time like me plan on probably heating up the plastic a couple of more times. But it does work as a great solution if you do it once and leave it alone!!
    Newbie k20fg's Avatar
    Jun 2012
    North Carolina
    40
    Awesome! I've been pondering how to fix my bumper tab! Props for the ingenious idea!
    Senior Member
    Damn great idea. I tried the bond the washer to the plastic it did not work for me since the tabs was to gone. Also they do make something like plastic weld my brother uses it on his bumpers. Its like a plastic fiber glass.
    Yeah I want to try the plastic weld next time around
    This really is an awesome idea. I used PlastiFix, it's a powder that turns into plastic when you apply a specific chemical to it (comes in the kit). Worked really well, but this free DIY idea is great! Repped for ingenuity
    Edit: You must spread some Reputation around before giving it to Spaz again.
