Results 1 to 10 of 13
Thread: engine stall after catch can install
    Newbie boostd05es2's Avatar
    Sep 2012
    long island
    sup dudes, got a kswaped 7thgen with greddy turbo just installed.
    turbo was recently rebuilt an im using the stock oil feed line and banjo return
    everything looked good but it would smoke if it idled for a few min
    didnt think its the turbo or the return line so i put in a catch can thinking it was a venting issue
    i removed insides of the pcv valve an routed the catch can lines to the pcv valve spot and also to the one on the valve cover and pluged the intake manifold bung.
    still smokes an now stalls when im coming to a stop
    i have no idea what i did wrong or what the problem could be
    thx for any input
    First things first, ditch that oil return. It will be a constant issue if it isn't already. Get it tapped/welded into the oil pan, or get the TSI oil return kit (if you can find one) since you have a top-mount turbo setup. The TSI return just replaces your timing chain cover with a bung on it. Nifty little thing.
    Next, the smoking could possibly be your turbo, seals might be gone. Was it a used kit? Also, how was the catch can mounted? Please post pics of whatever you can so we can help you.
    Oh, and to
    definitely in for photos....
    Sep 2012
    long island
    catch can pics
    thx
    catch can mounted behind passenger fog light,
    yea deff need to get rid if the banjo return think that is the problem
    with it burning oil
    cant find anybody selling that timing cover return plate tho
    im running 0w30 mobil 1 oil dunno if its too light or wat
    mayb its a combination of both
    also low revs it shuts off, got no idea about that havent gotten it tuned
    yet jus using the tune for the 440 injectors with greddy turbo on the kpro
    havent had any problems with this car before i installed the turbo
    thx again
    Attached Images Attached Images
    Sep 2012
    long island
    o and yea its a used turbo , it had shaft play so i bought the rebuild kit
    off ebay for $50 rebuilt it myself im sure i did it correctly sum guy on
    youtube made a video
    Quote Originally Posted by boostd05es2 View Post
    thx
    with it burning oil
    thx again
    Catch can is routed wrong. The IM (intake manifold) needs to be plugged. Go to Autozone, buy the rubber cap kit ($4.99) and a small hose clamp to fit around it. Cap the intake manifold off and secure it with the hose clamp. Don't make it tight enough to eat through the rubber, but snug enough so that it won't fall off. Next, run a line from the VC (valve cover) to the catch can as well. Make sure the catch can is vented. You should be all good. You're experiencing a vaccuum/pressure loss, because if that catch can isn't vented, you're pulling blow-by from your PCV line into your catch can and right into your IM. No bueno my friend.
    As for your tune, get it tuned ASAP! A tune will make or break your car. If you need a good tuner, E-Tunez is a sponsor on the forum. For a complete E-Tune, it's $199. And they're amazing. Get back to us when all is done, please include more pictures.
    Hopefully this issue will be fixed after you fix your catch can issue. If not, we'll take the next steps needed. Start with your catch can, fix it ASAP don't drive the car until it's fixed.
    Edit: Also, plug the port on your intake that the VC is currently going to (plug it the same way you'll plug the IM). Run a new line from the VC to the catch can.
    Sep 2012
    long island
    ok yea i will reroute the catch can thx!! as far as vented, its the weapon r
    http://www.kseriesparts.com/graphics...01_500x333.jpg
    dunno if this one is vented?
    deff gonna need a tune. where is E-tunez located, i was gonna take it to
    NoLimit in medford,NY but they want $500 but there 10min away lol
    i been workin on the oil return line. i emailed tsi and they are on back order
    for the return chain tension plate.
    i searched all over and found nothing, and removing the oil pan was not gonna happen.
    so i fabricated something.....
    ill see how this works lol
    That's great man!! Never thought of that
    I can say your timing chain will Be well lubricated. Lol. And I'm sure that will work but at what pressure does the returning oil come out at and at what temperatures? Not sure how this would effect the tensioner and guides. Just curious.
    Very nice idea I might add. It's simple and effective.
    Sep 2012
    long island
    THX!! that oil return plate was a one time thing hahaha
    i ran the car for about 15mins at idle... no smoke no leaks but gotta drive it around to be sure. deff wanna drive this thing again hopefully it doesnt make any problems for the tensioner down the road
    ill drill the cc an put a fitting with a filter an run new lines, also did u drill/punch out the pcv valve?
    and damn that sux they messed up ur turbo, they tuned my bro superchaged rsx, so i figured id go there, but they giving me the runaround. went there last sat and the tuner dude wasnt there so i left them my name an number for them to call me back but they havent yet. ill deff hit up VitViper
    yea i like doing all the work myself, but i find that i dont have the time anymore lol. try to work on it on my days off an use my parents element (K24 baby) for work.
    ill post more pics soon
    thx for all ur help!!
