So guys, a couple days ago I was going through my tool box and happened to find a bracket that I took off my transmission a while back.
And thought to myself this Would work great vs paying 25 bucks from crsx.
So I took and cut out the material between the two existing holes. ImageUploadedByTapatalk1348119321.599983.jpg
Then ground the tab into a shape of a tooth like on the flywheel.
Found some washers and a bolt and nut and you slide it through the rear lower hole for a trans bolt to go.
And your washers are meant to space the tool away from the engine block to line up and mesh with the flywheel teeth.
I had to place a little angle on the holder for it to work properly but that was no issue. It worked like a champ.
Hope you guys enjoy.
