If you can drop the trans you can easily rebuild it, it really is fantastically easy when you actually dive in. Things really can't go on in the wrong order and if they do, they won't line up and the issue will be obvious.
If you get an ep3 trans you can literally drop it right in, i made it complicated because originally i put the Ep3 gears on a 4.3 final drive. I decided that was a bit TOOOOOOOOOOO long for me. So i am now using the 4.7 FD that added a bit more work to my swap. If you get the gears and FD you want it will slide right in.
Some good tips though
4.3 FD needs this bearing HON-91003-PPT-004
4.7 FD needs this bearing HON-91003-PPP-004
You need to space out the speed sensor with 2-3 washers when using the rsx or EP3 gears in a z3 case.
Since I will be using my stock 4.7 fd as is, I won't need a new bearing will I?
