AEM Electronics Exclusive SALE Buy one get something FREE!
Buy any Series 2 EMS and get a FREE Serial Gauge Kit!
That's right... Free Serial Gauge!
Call today to place your order!
888-922-6686 or email Sales@Bisimoto.com
SERIES 2 KEY FEATURES
- Plugs directly into the factory harness. No rewiring necessary.
- Uses all the factory sensors.
- Includes start up calibrations.
- System is fully enabled and unlocked - Never pay for upgrades!
- Context sensitive help eases tuning process.
- Maps can be password protected by the tuner to prevent unauthorized -usage or sharing.
- Runs on Windows-compatible software.
- 8 direct-fire coil outputs.
- 16 general-purpose outputs.
- 8 definable switch inputs.
- 4 EGT inputs with fuel control.
- 1MB of internal data logging.
- Electronic boost control.
- Full idle control.
- Programmable traction control.
- Software definable knock control.
- Two step launch control.
- User configurable soft-cut rev limiters.
- Wet or dry nitrous control.
- Tune using new USB communication port or serial port.
- Works with all AEM gauges.
AEM’s Serial Gauge
Plugs into our Series2 or Series 1 EMS giving you the ability to read up to 19 channels simultaniously. Now you can read boost, AFR, EGT, H20 Temp, IAT, RPM MPH and more on one gauge with an easy to read, digital LED interface. You can link multiple Serial Gauges together to divide your reading across several gauges.
Buy any AEM Water/Methanol Injection Kit and get a FREE AEM Inline Filter!
WHY YOU WANT AN AEM WATER/METH KIT
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
WHY YOU WANT OURS
AEM’s Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
The AEM Water/Methanol Injection Filter
An in-line filter that uses a micronic mesh screen to filter particulates as small as 40 microns. This allows a cleaner flow of water/methanol to be passed into the engine, not only protecting the internals of the engine itself, but also the working parts of the water/methanol pump, too. Run the AEM Water/Methanol Injection Filter in-line before the pump to protect both pump and engine.
Buy any FIVE of these Widebands and get a FREE replacement sensor.
Call today to place your order!!!
Whether you have a mildly upgraded setup, or a full all out build, monitoring air fuel ratios (AFR) is a great way to make sure that your setup is performing at peak efficiency. It can also provide your aftermarket ECU with a constant data steam, allowing for closed loop oxygen sensor feedback, so that the ECU can "self adjust" for elevation, atmospheric and load changes on the fly.
Bisimoto endorses the "easy to install" AEM wideband UEGO system, and it is on sale now with free shipping within the continental USA!
Buy any FIVE of these Wideband Kits:
30-4100 Digital Wideband Gauge
30-4900 Wideband Failsafe Gauge
Get this FREE
30-2001 Bosch LSU 4.2 Wideband UEGO "Replacement" Sensor.
KEY FEATURES
- No free air calibration required - ever
- Accurate to .1 AFR
- Adjustable backlighting via a dial on the back of the gauge
- Two status lights for error detection and operating status
- Includes white and black gauge faces
- Includes black and silver interchangeable bezels
- 320 degree viewing area for unsurpassed resolution
- Includes Bosch 4.2 sensor for optimum accuracy and reliability
- 0-5v analog output included for use with data loggers and virtually any engine management system
- Reads Gasoline values from 8.5 to 18:1 AFR
- Reads E85 values from 5.7 to 12:1 AFR
- Reads Ethanol values from 5.2 to 11:1 AFR
- Reads Methanol values from 3.7 to 7.8: AFR
- Reads Lambda values from 0.58 to 1.22 AFR
Bisimoto Engineering - Where Effeciency Meets Technological Perfection
1-888-9bc-moto (1-888-922-6686)
http://www.bisimoto.com/
Email: sales@bisimoto.com
Contact us for the best deals on AEM Electronics and Turbonetics turbos
Newbie
Newbie
Bump for great prices on AEM EMS!
Call today for pricing...
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
