Quote Originally Posted by 06_typeS View Post
Well I made it home for a few weeks. Got to drive the NSX for a bit before I got very discouraged with it. While inspecting the car after I pulled it out of my Grandfathers garage, I opened up the trunk to find a huge mouse nest. Housing insulation, trunk carpet, paper and shit all rolled up in a ball in the corner of the trunk... FML.... So after cleaning that out, and inspecting for chewed wires I found nothing. I then took it on a road trip to the states for a weekend when it started acting up. 1st was the passenger side window would not go down, which it misteriously cured itself on the drive home?!?! Next was a missfire/sputter under load from 1000-3500 rpm. So pretty much in every gear driving at normal speeds. At times on the highway I would have to leave it in 4th just to stay above 3500 to avoid the sputter. And last was a huge oil leak. The car always leaked a bit of oil, but this leak was a steady drip (approx. every 3-5 seconds) coming from one of the vtec solinoid gaskets (which was replaced from Acura 2 years ago).
So it spent the last few days that I was home at the dealer getting repaired, which I still havent heard if I got a bill or not. Big thanks to [MENTION=49]boosted_teg[/MENTION] for picking the car up on a few different occasions and putting it in storage for me.
So next on the agenda for the NSX.... More maintenance. I am going to start with replacing both o2 Sensors (which I have, just didnt have time to install), new coil packs and spark plugs, ignition igniter, main relay, and fuel pump.
On a side note, I did get the BBK, CF hood & spoiler, steering wheel/quick release, and exhaust on. Headers and rear lower valance will have to wait until the next time I am home, which isnt planned for anytime soon.
Mice?! At least you weren't attacked and it seems like no real harm was done, other than a time-consuming PITA situation. House insulation sucks too, soooo itchy. The same thing happened to the passenger window on my vette. Motor rusts up where the magnets contact and the window doesn't move. It's very common on the C5's. Screw driver and a hard hammer hit on the bolts that hold the motor while holding the down button and she moved right down!
Maintenance is all a part of the fun my friend. If you have a trusted friend local, have them start it up every few weeks. Tends to save lots of headaches. An object in motion tends to stay in motion. Glad you got to drive her for a bit though! I'm sure next time will be better
