Page 1 of 3 1 ... LastLast
Results 1 to 10 of 24
Thread: Fuel Rail Discussion
    I figured this would be a good time to start a discussion about fuel rails. I'm trying to figure out the difference between using an aftermarket fuel rail and an oem fuel rail in terms of tuning. In my situation, both rails will use 1000cc FIC injectors and will be returnless. I need to figure out how to adapt a K-Tuned rail to my 06-11 Si without running a return line. IIRC, I need to use the oem fuel damper with my setup. Thanks in advance for your help.
    Truthfully I would just not waste my time and keep the OEM if you aren't going to build a return line and need the burp valve.
    Newbie k20fg's Avatar
    Jun 2012
    North Carolina
    40
    Yeah I'm with Spaz on this one .. unless it is for looks I would stick with the stock fuel rail, couldn't imagine there being any bump in performance or any tuning related issues.
    One of Hybrid rails does have an input for the factory pulse dampener that you would need to run if your staying returnless.
    It's for looks. I want to swap it for the OEM rail but I want to make sure it works the way it should. No issues, no fuel starvation, etc. What would I need to make it work?
    You'd want a return line with a fuel pressure regulator built off boost verse one constant pressure setting This will lower your fuel injector duty cycle making them more efficient and keep a more even constant flow a fuel to them. As much as you don't want to run a fuel return line I will argue with you all day that if going turbo you will want to so you can run an Adjustable FPR based off of vacuum pressure and keep fuel flow constant/consistent and run more pressure to the injectors than the stock FPR can do.
    I agree 100%, but the funds aren't there in the mean time. I plan to do it in the future, but in the mean time I'm stuck without one. So I need to run an adapter for the OEM damper, just need to figure it out.
    or... just leave the stock rail... paint it, polish it, do whatever and just save the new rail and start collecting the matching parts/accessories. Before i bought my HR I sanded down and painted my factory one and it looked a lot better
    Its really that big of a difference? I'd rather not show up.to Honda Day with a stock fuel rail, but ill see what I can do. Wanna PM me a mini write up on how to tuck the wires that sit in that plastic case on top of the oem rail?
    Is it that big of a difference if you use the aftermarket rail without a return? As long as you have the OEM damper, you should really be fine. Especially if it's a rail just for a show.
    i did mine a bit in april, looks a ton better!! also tapped the bottom of the mani and ran the brakebooster and evap line there.
    but it looks alot better on the RSX because of how the heater lines and upper radiaor housing run compared to the si
