Page 29 of 30 FirstFirst ... 1929 ... LastLast
Results 281 to 290 of 296
Thread: My a2 billet 6265 turbo build
  1. #281
    ya Joe,i probably couldve. Ill have to see what happens this summer. Id just hate to part it out, and thats only way id get any money back. Plus, it seems like nsx are going up in price now
  2. #282
    its been a slow process. Bought an s2k pump to be modified and a few other small stuff.
    We are still getting snow, and i was getting depressed so i went to the garage and took the cover off.
    I picked up another project for the GF. She bought it. We're taking the k20a2 swap out of the ek hatch and putting it into this.
    2000 civic SIR (SI for you guys in the steates :P)
  3. #283
    ive been busy last week installing k20a2 swap into the gfs new SIR coupe.
    I removed my clutch to put in hers and well, shes toast. I kindve figured it was slipping at the track
    Removed the k swap from the hatch to put in the coupe
    then i got bored, so decided to test fit my turbo and manifold.
    I ran into a small problem. Using the z1 head, the coolant ports on the back arent the same as a A2 head. There fore, my bottom wastegate runs right into the coolant thing on the side of the head. I called Mike at ktuned, and he thinks their side adapter will help clear. If it doesnt, i dont know what else to do beside running no heat
  4. #284
    Quote Originally Posted by boosted_teg View Post
    Update?!
    Sent from my SM-G900T using Tapatalk
    Not much to update.
    Got everything in. Installed the aem infinity, went to update and the program crashed. Long story short, it's at aem for the past week awaiting repairs.
  6. #286
    Newbie jdmdomo's Avatar
    Oct 2014
    Very , very nice
  7. #287
    Not much to update.
    That sounds like a whole lot of fun lol
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  8. #288
    over a year later, and it still isnt done on the dyno. Between AEM infinity, tuners and vtc issues, im almost ready for a part out.
    Got it to the dyno and left it there. First thebrand new ktuned v3 hall effect sensor was shot. I had to send up my spare tps to fix it.
    Alt belt broke.
    Now im having vtc issues. Its not following the target vtc. Not sure if its a setting in the infinit wizard, or need a new PNC vtc sensor.
    next step is to put back kpro
  9. #289
    One issue, after initial dyno session mid summer, came to realise i was leaking out compression on a cylinder. Did a leak down and somehow i had 2 bent supertech valves.
    So i replaced them all with ferrea comp plus valves.
    on the way to the dyno. Honda hauling the acura :P
  10. #290
    Heres some pictures of the motor.
    AEM plate
