Quote Originally Posted by fg2onboost View Post
So i have a pretty cool idea for a fuel system.
i plan on using race gas and i do not like the idea of having to drain and refill when switching from race gas to pump gas.
so in order to get around all of that, im going to be using a 5 gallon fuel cell with 2 bosch044 fuel pumps for race gas use.
so here is how it will work.. there will be a fuel solenoid on the factory feed line and a fuel solenoid on the race gas line coming from the fuel cell... obviously there will be 2 switches 1 for each fuel system, there will be an arming switch for the fuel pumps and solenoid on the race gas system.
as for the return line.. there will be a return line going back to the fuel cell also governed by a fuel solenoid.
As i am sure that anyone who knows about fuel solenoids there are some that can stay open for an extended period of time and those that will burn out if they are open for more than a minute or so. i will be using custom made heavy duty plunger type solenoids.
Just to clarify, you won't have both tanks with gas in them at the same time, right? That's a decent amount of extra weight in the rear. If so, think about stiffer rear springs. Other than that, sounds like a good idea! Pics if you can
