Cleaned up my hubs with a wire brush then painted them black to clean them up
then slapped my suspension on
Went ahead and clamped down my Fuel lines, and installed the return line
Also pulled out the studs and bolted down the HR water port for good
Then grabbed my Harness and installed that
My own clutch line I sell
And then had to make a new Map Sensor bracket. So I grabbed out some sheet metal. Traced my map sensor
then did a rough cut out
Now to find hole position I used red marker and a pick to scratch a center
tough to see.. but here is where to drill
Now drilled my holes
drilled the top hole and cleaned it up
Now to install and tuck away
