Page 23 of 27 FirstFirst ... 1323 ... LastLast
Results 221 to 230 of 264
Thread: Adm_rsx's Rotrex build part DEUCE
  1. #221
    Well my UEGO wiring harness came in today. great news is that fixe my wideband issue. So as soon as my plugs, and O2 bungs come in from kseriesparts.com
    My nylon hose from summit, and my remaining push to connect air fittings come in from McMaster-carr... I'll be able to start the thing up.
  2. #222
    Looked like Christmas today at work. Was receiving boxes left an right from UPS and FedEx.
    Summit:
    Kirkey seat cover for a badass seat
    1/8" nylon hose for pressure regulator
    1/4" nylon hose for BOV
    CRSX:
    Vibrant O2 sensor bungs for aem wideband sensor
    And plugs.
    McMaster-Carr:
    1/4" push-to-connect fitting
    1/8" push-to-connect fitting
    Should be able to start the car tonight. Just have to weld to O2 bung in and route the UEGO harness to the gauge.
  3. #223
    Well I couldn't start the car only because the 2 air fittings I received today were too big. I ordered 1/4" NPT. I knew better but didn't check first so lesson learned.
    But I managed to weld in the new O2 bung. And my friend put the cover on my seat. It's actually more comfortable then I thought. Thankfully. Lol
    Once I hit that point I decided to wait until tomorrow to start it. I'll have more time to triple check things. And I just finished grinding the calipers to fit the 15" wheels for my slicks.
    Before:
    After:
    End result:
  4. #224
    Nice wheel choice
  5. #225
    Nice wheel choice
    Thanks man. Exospeed star 8's.
  6. #226
    I love McMaster-Carr. Bought the fittings yesterday at lunch when I realized the ones I had were too big and I have them in hand. Glad they ship fast.
    This means the car WILL fire over tonight.
  7. #227
    Jul 2012
    Can't beat that
    http://i823.photobucket.com/albums/z...C3937DC695.mp4
    Car started to overheat on its first start up because the thermostat wasn't opening. So I took it out all together.
    But the car was picking up quite a bit of knock doing a couple free revs. Not very high. Maybe 3500-4k rpm.
  9. #229
    I had the same issue n it ended up being my valve adjustment on the knock
  10. #230
    So did you just adjust the valve lash?
