Adam is the cooling system bled out properly ? K series cooling systems are a pia especially if the system was completely empty .Did you jack the car up in the front as high as your jack will go ? Stick a funnel in the rad and allow it to run while monitoring the level in the funnel ? also helps if prior to beginning the process you pull the top hose and fill the block that with a temporary hose at the block fitting leaving the rad hose a little loose at the rad so you can turn it quickly and put it on the block fitting you spill a little coolant this way but it helps fill it .I had the same issues with overheating when I first did my swap and after ordering a new t stat for no reason and some searching I now have no issues bleeding out my cooling system anytime I have needed to .As far as the knock not really sure what to tell ya superchargers are noisy and will likely cause some knock don't most / a lot of tuners disable the knock sensor anyway especially on a s/c set up
