Next we will have to modify the top of the housing cage. Because the pump is longer the housing will not shut. So place the pump in and mark off the area that needs to be cut. Then cut it out.
Now we will cut the old hose off from the top as we will not be needing it.
Put the cage back together and clamp down the new hose. Remember not to tighten this side of the hose down as tight because it is going on plastic!!
Now reinstall the fuel pump into the tank!
and you're all done!! Simple as that!
