Results 1 to 10 of 16
Thread: My Intro AKA Str8JDM 10 sec Honda Day Build
    Jul 2011
    THIS POST WILL INCLUDE ALL THE MOTOR BUILD PROCESS AND PARTS
    K20Z1 block stripped and ready for the machine shop
    K20Z3 head stripped and ready for the machine shop (picked up a head that only had 800 miles on it!)
    Crank back from machine shop all boiled clean and polished
    ARP Head Studs, wouldnt trust anything else
    Deatschwerks 300LPH pump, Walbro so last year..
    Wiseco 86.5mm pistons, 9.8:1 compression, Eagle H-Beam Rods, Upgraded Wrist pins
    Left: Standard Wrist Pin
    Right: Heavy Duty Upgraded Wrist Pin
    ACL RACE Bearings
    block back from machine shop ready to go!
    IPS KT1 Cams, Accord Type R Exhaust Gear
    Head back from the machine shop, all new guides, seals, and a mill job
    Competition Stage 5 Clutch
    Fuel System ready to rock (look for a fuel return DIY in about a week)
    Injectors came back from Fuel Injector Clinic, they were flow tested and cleaned, mint...
    Innovative 75A Motor Mounts
    EM1 CMC with Hybrid Racing Clutch Line
    Manifold With TSX Throttle Body
    Precision 6262S CEA
    Bottom End Built, ready to rock
    fuel cage all done, dw300 to -8 feed, -6 return
    Blow off valve location moved...
    Valve cover with -10 ports welded in for catch can...
    Candy Purple Powercoat!!
    BC Coilovers 8k/10k, Beaks Bar, 8mm Spacers for Slicks
