Results 11 to 15 of 15
Thread: EFR EP3 build
Threaded View
    Senior Member bluEP3_SC's Avatar
    Aug 2013
    NY / NJ
    EFR EP3 build
    It's been a long road with this one. It started as my DD for 10+ yrs and it's been through plenty of changes- from k24a2 swapped to supercharged/ aftercooled/ e85 to blowing up the k24 and swapping in a JDM k20a with the supercharger then selling off the blower and going all out with a Fullrace EFR8374 kit. Let's see where the road goes from here...
    Guts:
    03 JDM dc5r k20a engine
    -k20z3 upper chain guide
    -HPT lower chain guard
    -Tractuff oil pan baffle
    03 JDM dc5r 6 speed LSD trans
    -CC stage 4 clutch kit
    -CC ultra light flywheel
    -Mspec race shift springs
    -Hybrid racing shift cables
    -ktuned CMC upgrade w/ braided clutch line
    FullRace Motorsports EFR Turbo kit
    -EFR8374 t4 0.92ar turbo
    -jet coated black hot side
    Turbosmart iwg75
    Turbosmart BPV
    Vibrant 4in velocity stack
    Max bore OEM throttle body
    RBC intake manifold
    Hybrid Racing rad hoses (EP3)
    Hybrid Racing oil cooler hoses
    Hybrid Racing fuel rail
    Hybrid Racing AC/PS delete kit
    Hondata 4 bar MAP sensor
    DEI gold reflective tape
    Ktuned spark plug cover
    Ktuned oil cap
    Ktuned dipstick
    Ktuned drain plug
    Ktuned TPS sensor
    Ktuned idle air delete
    Ktuned tensioner cover
    Custom Kteller straight pipe 3in Exhaust w/ vibrant ultra quiet resonator and turn down
    Custom 4in turbo inlet w/ AEM filter
    Alcohol Injection Systems 3 gal trunk mounted meth kit
    -18gph nozzle in intake tube
    -steel braided line upgrade
    AEM progressive meth controller ver2
    Innovative 75a motor mounts (4)
    Ingals Stiffy engine torque dampner
    Buddyclub Spec Condensor
    T1R IAT sensor
    Mishimoto low temp fan switch
    Mishimoto radiator
    Mishimoto catch can
    Mishimoto 12" slim fan
    NGK 9s
    ID1000cc injectors
    AEM fuel pressure regulator
    Aeromotive fuel filter
    DW300 in tank fuel pump- hardwired
    Russell's -6an steel braided supply and return fuel lines w/ black hose ends
    Bolt boys (downstar) complete engine, trans, mount, and chassis SS hardware
    Stiff stuff:
    BC racing type BR coilovers
    Hard Race roll center adjusters
    Energy suspension poly front LCA bushing kit
    Energy suspension poly front sway bushing kit (stock bar)
    Corsport adjustable metal sway bar endlinks (front/ rear)
    Energy suspension rear trailing/ hub poly bushing kit
    Ingals camber bolts (front) adjustable camber arms (rear)
    DV race adjustable tie rods
    T1R inverted tie rod ends
    Aspec front tower brace
    DC5R front lower brace
    Skunk2 rear lower control arms
    Cusco 25mm rear sway bar
    Megan racing rear tower brace
    Mugen mid rear tower bar
    Megan racing C pillar bar
    Progress rear lower tie bar/ brace
    Stoppers/ rollers:
    Wilwood dynalite 4 pot front BBK
    -2 piece rotors
    -race pads
    -steel braided lines
    -HP600 brake fluid
    PassWordJDM rear slotted/ drilled brake rotors
    Hawk HPS rear pads
    Technafit rear steel braided brake lines
    Buddyclub P1 racing SF challege wheels
    -17x7
    -+42
    10mm H&R spacer (front)
    5mm H&R spacer (rear)
    Bridgestone Potenza RE-71R 215/45/17 tires
    Inside:
    Hondata kpro ver4
    Buddyclub P-1 racing bucket seats
    Buddyclub racing seat rails
    Buddyclub short shifter
    UKDM CTR gauge cluster
    JDM CTR center console
    LHD CTR floor mats
    Corsport shifter base bushings
    ICB motorsports weighted shift knob
    EBAY shift boot
    AEM wideband gauge
    AEM boost gauge
    Custom carbon dash insert
    Custom battery rear mount
    Custom meth tank tear mount
    Outside:
    Beater
    -JDM front end w/ VIS racing Mugen rep front lip
    Show
    -JDM front end w/ airwalker japan front lip
    -SSR carbon rad cooling duct
    -ARC EK4 winglets
    HFP side skirts
    DEPO JDM CTR rep black housing headlights
    Seibon OEM carbon fiber hood
    Aerocatch locking hood pins
    PasswordJDM quick release bumper ties
    HFP rear wing
    JDM front and rear red H
    Golden eagle rear tow hook
    Might be some that i missed but thats most of it.
    Car is tuned by Derek @ IMW
    420whp/290wtq@14psi on pump 93
    Thanks for looking
