Exhaust and downpipe are made
Instagram [MENTION=1242]Sheaperk[/MENTION]
Well the fabricator is too busy at the moment. So i went a picked up the car and brought back home to a local badass exhaust shop.
Downpipe is well underway now!
Love the fender exit! Will you be outlining the hole with a CF/SS plate?
It will definitely have a beauty ring of some special sorts!
Local fabricator knocking out charge pipes and mounts for intercooler! 😀![]()
Awesome! Fabricator does nice work!
Awesome build dude. I'm building an ep3 too and I want to do a similar down pipe, except exit on the other side of the car. Do you have any pictures of how you snuck that pipe through or what you cut from the inside of the bay?
Cammed ss camaro dyno'd 460whp
Turbo k20 6266. 22lbs
http://youtu.be/NQwQbMOAyxA
