I replied some in the other thread. I did what aem said. Level out the timing at idle, leveled out the target afr at idle and few more settings.
It didnt make much fo a difference. Actually, it would only run for 15 seconds then die. got worse. I deactivated each injector 1 by 1 and the car is firing on all 4.
So i hooked up kpro and it fired up/idled off a 1 minute basemap i did. No codes. There seemed to be a small miss from listening to the exaust, but that could be anything.
Im going back on NYE and going try activating the iacv with AEM, and put the factory settings from an a3 map in the iacv pid tables.
If it doesnt idle and work soon, theres a nice 92 nsx for sale in canada for 28k. Part out mighthappen
