Page 1 of 2 1 ... LastLast
Results 1 to 10 of 19
Thread: 800+hp fuel system?
    Newbie Jus abase's Avatar
    Mar 2014
    800+hp fuel system?
    Single dw350il> -8 feed> aem rail> id2000. Anyone know if this combo will hold low 800's? E-85
  4. #2
    Senior Member Shanket's Avatar
    Jan 2014
    Corpus Christi TX
    Age
    33
    i believe so mike is runnign dw 300 with -8an feed and-6an return id 2000 and bosch 044 under so far he has made 600 on 15 psi on e85 cause boost leak and 1000cc id on c16 made 700
  5. #3
    Jan 2014
    Corpus Christi TX
    Age
    33
    im running a radium multi pump with two walbro 485 and feed -8 an and -6 an return with id 1000cc on e85 i believe rated for 900-1000
  6. #4
    Is this with a return setup or returnless?
    Senior Member Spoolin_VTEC's Avatar
    US
    ^ This. I suggest going return, because it seems like you're going for returnless. It's more work, but much better and prevents that dead end situation. Just my
  8. #6
    Super Moderator
    Spaz's Avatar
    Quote Originally Posted by Shanket View Post
    can't believe you're only running 1000cc with that setup. It's a great setup don't get me wrong. But I don't see 1000cc hitting 900-1000hp. I maxed out mine on 500whp on E85.
    Jan 2014
    Corpus Christi TX
    Age
    33
    Quote Originally Posted by Spaz View Post
    im staying on 1000cc for now i will be upgrading once i work out all the kinks i know it wont hit 900 max is 500-520 on 1000cc
  10. #8
    Premium Member boosted_teg's Avatar
    nb, canada
    i dont even think a single dw350 is going to touch 800whp on ethanol.
    2001 Boosted Built k20a2 Billet BB 6766BB
    2013=579whp 406trq @ 24 psi c16
    10.87@137mph
    2014= 510whp 370trq @ 18psi pump gas
    2015= 7xx @ 30psi??
  11. #9
    US
    Time for a Bosch 044 addition. I just saw that the eshop on here is running a sale on southbay injectors and stuff. Awesome pricing actually, sick deal for a set of 2200cc;s with pigtails or clips.
  12. #10
    I made over 600whp on C16 with 1000cc injectors, and a fuel return setup.
