sstream - mate of mine had his setup mapped this week just gone, using a lightly modded PLM mani and downpipe.
as said mani needed a little tweak to clear the wastegate away the water pipe on the block and to improve wastegate placment a little. downpipe also needed a tiny little bit of modding to avoid hitting the floor, ARB and subframe.
results ended up good! 357bhp and 271lbsft at the fly at 7 psi on a gt3082 .82 turbo. only reason they stopped at that was his boost solenoid turned out to be a 2 port affair somehow so had limited affect on increasing boost, and he also only has a 2.25" catback so pushing past 350bhp would have caused strange graph lines. he is expecting an easy 400bhp at 10 psi once all issues have been adressed.
lads - how do you "mention" someone? cant seem to get it
