Well, I can contact [MENTION=903]Boost Junkyz[/MENTION] for you to see what he could do for your setup. He's super busy but loves to help the community when he can. Maybe he will make a decent log or top-mount manifold for you.
What is the good top mount turbo manifold,because i see them on ebay but they are not worth it,cheap junk.
Wysłane z mojego D2303 przy użyciu Tapatalka
From what I've seen and tried on UK cars,
Full race, TD autowerks, MAP performance, F5 performance, AFI, spooling fabrication, nortech and solid fabrications all fit and work fine with no issues with reference to turbo and wastegate. Just the usual relocation of fuel, water and brake booster lines which you have to do with pretty much all k20s
However, all require modded off the shelf downpipe and screamer or a custom/ home made affair. Which tbh, isn't all that difficult if you can borrow a MIG welder just for tacking.
From UK myself if you need anything
You guys should post up in the international section!
sstream - mate of mine had his setup mapped this week just gone, using a lightly modded PLM mani and downpipe.
as said mani needed a little tweak to clear the wastegate away the water pipe on the block and to improve wastegate placment a little. downpipe also needed a tiny little bit of modding to avoid hitting the floor, ARB and subframe.
results ended up good! 357bhp and 271lbsft at the fly at 7 psi on a gt3082 .82 turbo. only reason they stopped at that was his boost solenoid turned out to be a 2 port affair somehow so had limited affect on increasing boost, and he also only has a 2.25" catback so pushing past 350bhp would have caused strange graph lines. he is expecting an easy 400bhp at 10 psi once all issues have been adressed.
lads - how do you "mention" someone? cant seem to get it
Yes
That is a hell of a restrictive exhaust!! For [MENTION=1228]sstream[/MENTION], a PLM mani and 3" downpipe would be nice when coupled with a GT30R.
As for mentioning/tagging someone, type @ and the user's username immediately after. So, I would type @ jonezy but without the space between the @ and the username, resulting in this: [MENTION=1040]Jonezy[/MENTION]
Yes to what?
Is there any list for what to get to do turbo conversion on k20?
There is quite a lot. Will get the spreadsheet up.
