Hybrid Racing Fuel Rail (Feed&Return Setup)
This is basically everything you need besides a bigger fuel pump. Its has all the lines, clamps, FPR, and inline fuel filter. The gauge that is on there is messed up. When i bought it the needle fell off. A new gauge is like 20 bucks.
$500 Shipped
OEM TSX Projectors (DS2) w/ Shrouds, Bulbs, PnP HID Adapters
Condition:
Lens:I tried to take pictures of the lens but it was hard to get. Some dust could use a proper clean.
Shrouds: One is modded, once installed you can't see it.( right one, on the left side in the 1st pic.) One thread housing is broken BUT the screw threads in not problem and hold nice and tight(see pic 4). Once has some small scratches on the outter end. They to need to be whipped off.
Projector housing: Lots on silicon gunk on the backs. It rubs off with your thumb. I gave up after a while cause my thumb was getting raw. There was a fuck ton more then what is left.
Bulbs:There was a recall on my EP on the combination switch melting and cut all power to the headlights. I dunno if they still work, cause my headlights went out and before i took the car to honda i took them off. i figure they're a freebie. If they do then your set, if not you need to buy D2C HID bulbs. That is when i took the headlights off.
Adapters: Perfect, only used for 3 weeks.
Price: $300 Shipped for it all.
#1
#2
#3
#4
#5
#6
#7
#8
#9
Braided vacuum lines.
Meant for a boosted car, could use them on one that is not. There are the lines on the bottom closes to the camera.
Price:$150 Shipped
SSR Rep Prefacelift JDM front
Has some shipping dents. Body shop will have to do a simple fill on a couple spots but nothing serious.
$1000 Shipped with CTR lip and OEM type-r rebar
JDM Rear Bumper with lip and custom rebar
The tabs are broken on the inside but its a easy fix. I'll fix it with DP-100 and aerospace grade adhesive.
Price: 1400 Shipped thru greyhound.
I'll provide more pictures upon request.
