Results 41 to 50 of 50
Thread: New Member! K20A Ep3 431whp street car!
Threaded View
    Newbie
    Dec 2014
    UPDATE: Interior pics on page 2 & few build pics on page 4...
    Whats up guys. My name is Luis and Im from NJ. Heres a quick run down of my pride and joy. The car was built by myself from the ground up. Motor was built by Larry at Pro-Motion Race Engines and tuned by the man Yosolo. Car made 431whp @15psi 93 pump gas on the dyno but boost creeps to 19psi on the road. Heres the spec list and just a few pics I have. I plan to do a build thread soon so stay tuned. Hope you enjoy.
    Motor:
    ITR K20a Type R
    Type R Cams
    Supertech Titanium dished Valves
    Supertech Titanium valve seats
    Supertech dual valve springs
    CP Pistons 86.5mm 9.0 cr
    Manley Turbo Tuff rods
    Mahle Clevite race bearings
    OEM chains
    OEM guides
    OEM tensioner
    Precision 5831 Turbo
    BWR T3 sidewinder manifold
    Tial MVS 38mm wastegate
    Tial 60mm BOV
    ID1000 injectors
    Ktuned fuel rail
    Ktuned fuel pressure gauge
    Aeromotive A1000 fpr
    Eagle oil feed plate
    Ktuned gaskets
    DW65c fuel pump
    Earls 10 micron fuel filter
    Russell 6an fuel lines (feed & return)
    Ktuned an fittings
    Vibrant 2.5" piping
    Vibrant couplers
    Type R 6 speed trans
    Type R oem LSD
    Clutchmasters stage 4 clutch
    Hybrid racing shifter cable bushings
    Innovative 75a motor mounts
    CXRacing Intercooler
    MTEC Trans shifter race springs
    SSR Engine torque damper
    Samco Sport Radiator hoses
    Ktuned AC/PS delete
    Custom 3" downpipe (open)
    open dump tube
    Hondata Kpro
    Exterior:
    Type R headlights
    6000k HID's
    LED parking lights
    Custom Cupra R Lip
    OEM 04-05 sideskirts
    Mugen Seibon carbon fiber wing
    Custom DIY rear wiper delete
    35% tints
    Tinted taillights
    LED plate lights
    Interior:
    Corbeou Forza seats
    Corbeou 3inch 4 point harness
    NRG steering wheel
    NRG slim hub
    NRG quick release
    Buddy club short shifter
    Corsport shifter base bushings
    Custom radio delete
    Broadway mirror
    NRG harness bar
    Custom X-brace designed by myself
    Rear of the car is completely stripped and wire tucked. Painted and clear coated to match exterior paint.
    Suspension:
    Skunk2 Pro S coilovers
    Custom spring lengths and spring rates
    10kg front/ 8kg rears
    Skunk2 rear camber kit
    Spc front camber bolts
    Beaks tie bar
    Progress tie bar and sway bar
    Wheels:
    Old setup:
    XXR 527 wheels
    17x8.25 f/ 205_40 Falken 912's et20
    17x9.75 r/ 215_40 Falken 912's et10
    New setup:
    ESM 007 Platinum edition wheels w/gold rivets
    17×9 all around
    215_40 Nankang Noble sport NS20
    Front et 20
    Rear et 5 (using 15mm H&R spacer)
    H&R extended studs all around
    Here are a few pics. Ill post more as go along
    A pic someone took down at H2oi in Maryland
    And heres quick pic I snapped after fitting the new wheels and test drive
    Dyno vid: https://www.youtube.com/watch?v=UHFo32VPXyo
