Page 2 of 2 FirstFirst ... 2
Results 11 to 20 of 20
Thread: hi/low boost switch?
  1. #11
    Jan 2014
    also, the switches you use. do they need to be the 2 connector or the 3 connector type?
  2. #12
    Jan 2014
    Sorry about the relentless questions but this is what I've understood,
    This correct?
  3. #13
    Moderator ryaano18's Avatar
    Mar 2013
    Houston
    Quote Originally Posted by Jonezy View Post
    either will work. 2 pin are regular switches, power to one and signal to other.
    3 pin is same except one pin is ground (these are usually for switches with LEDs)
    and your diagram is correct
    Need Parts? Click HERE
    Wanna learn some wiring?
    Click HERE
    PM me for wiring supplies and inquiries
  4. #14
    Jan 2014
    awesome, thanks very much fellas. glad to have a definite answer. loads of threads about this but none actually wrap the whole thing up.
    just one last question. in the dropdown menu in kmanager for the hi boost activation switch, it mentions the E16,E22, E26 and E29. Do these not do the exact same thing as using brake light switch?
    cheers
  5. #15
    Look at you doing electrical diagrams! There is a pen that was recently released to test circuits on paper. I forget the name, but it's pretty cool! Anyways, good luck doing this. Keep us in the loop!
  6. #16
    Jan 2014
    tbh i will probs just go with the brake light switch as its not of any real consequence to anything else.
    went maplins and bought small rocker switch last night. only rated to 3Amps mind, is that enough or will i need summat more substantial?
    sure will check back in with you fellas, nothing more annoying when those you help drop off the grid i bet!
  7. #17
    Mar 2013
    Houston
    3 amps is fine for a signal. Signals are very very low amerage
    Click HERE
  8. #18
    Jan 2014
    Cheers pal. Thought as much as switches any higher are quite bulky.
    Thanks fellas
  9. #19
    Newbie djtooon's Avatar
    Feb 2014
    NJ
    Great info on using the Brake switch
  10. #20
    Jan 2014
    Hey there fellas.
    Finally got my boost by gear woes fixed. Car is great now!! Just the wrong time of year as it rains like crazy all the time here!
    Can confirm for definite that using E22 as per the diagram and the 12v live (yellow and green) from the cig lighter definitely works!!
    Very easy to rig up, can't belive how much I over thought it.
