thanks for the offer pal, wrong side of the pond to be posting things to me though. apprieciate it mind.
so only the brake light switch can be used? just curious why other inputs such as...
E16 power steering pressure switch
E29 service connector switch
why are these mentioned? and how would they react if treat same as you mentioned for the brake light switch?
also the question of the brake light switch? this does definatly refer to the light on the dash? not the brake lights on the rear of the car?-EDIT - http://www.hondata.net/forum/viewtopic.php?f=12&t=6440 thread clears it up a bit, all it does it raises idle slight;y when brakes are applied!
would the handbrake warning light also still work?
