Results 1 to 10 of 20
Thread: hi/low boost switch?
    Moderator ryaano18's Avatar
    Mar 2013
    Houston
    From what I've gathered so far that's the only wire
    Ahhhhh thanks for clarifying that. Well [MENTION=1040]Jonezy[/MENTION] you could still cut it and extend to a switch, or you can depin the brake wire, and repin a flying lead to a switch and just tuck away the oem wire with tape.
    Need Parts? Click HERE
    Wanna learn some wiring?
    Click HERE
    PM me for wiring supplies and inquiries
    Jan 2014
    also, the switches you use. do they need to be the 2 connector or the 3 connector type?
    Mar 2013
    Houston
    Quote Originally Posted by Jonezy View Post
    either will work. 2 pin are regular switches, power to one and signal to other.
    3 pin is same except one pin is ground (these are usually for switches with LEDs)
    and your diagram is correct
    Click HERE
    Jan 2014
    Sorry about the relentless questions but this is what I've understood,
    This correct?
