Results 1 to 10 of 20
Thread: JDM K20Z2 Motor Questions
    My guess is 7600 like the stock k24a2 I had is the max I'd rev as im not all that familiar with the k20a3 nor your z2 but at 7600 you should do well.
    The crank I'm sure youd have no problems with at 8k. But the rod bolts is your only foreseeable weak point.
    When you installed the RRC pistons did you use RRC rods as well? [MENTION=1126]nomad[/MENTION]
    Well said x2
    Oct 2014
    Thanks for the reply..no, i didnt change the RRC rod as the size are bigger and cant be fitted into the stock k20z2 crank shaft..but the pistons are interchangeable..
    Here's are my mod:
    1. k20 cl7 cylinder head
    2. k20 FD2r camshaft
    3. k24a2 310cc injectors
    4. RRC 11.7 CR pistons
    5. RRC intake manifold & throttle body
    6. Hondata flash pro
    7. Fd2R 6 speed MT gearbox
    My foreman told me it could make 200 whp or higher with higher RPM (>8k) but i was afraid as it might just blow out...well, after reading your post i'll stick to my current 7600 rpm..thanks guys...
    Quote Originally Posted by nomad View Post
    Here's are my mod:
    Gotcha gotcha. Yea I would play it safe but im pretty sure you can make ~220ish whp with the mods you've listed. Even at only 7600rpm.
    Oct 2014
    thanks for the advice..im still on running in period and will bring it for dyno soon and will upload the chart..hopefully it can make ~200 whp..
    Please keep us updated with information, pictures, and even video!
    Senior Member 02civic629's Avatar
    Mar 2014
    VA
    I really say it depends on bolt ons and how much air hes moving....... Im still at ~200whp at 7600rpm
    Quote Originally Posted by 02civic629 View Post
    But remember... He has RRC pistons
    Mar 2014
    VA
    Idk from the test I've done with my car and compression ratio differences it is deff gonna help him but how much still depends on bolt ons/air flow. I'd give him the ~220whp range with a big boy intake/manifold and a big boy header/exhaust system but with off the self bolt ons that's a stretch. His weak point will deff be the rods though cause that's the same problem I have lol.
