Page 3 of 3 FirstFirst ... 3
Results 21 to 26 of 26
Thread: Low Boost Problem
  1. #21
    Nice! Did you do the fabrication yourself? [MENTION=888]Brezno[/MENTION]
  2. #22
    Newbie Brezno's Avatar
    May 2013
    Germany
    Yes i did it myself.
  3. #23
    Explains why he has boost creep problems? Or just explains how it's setup? Based on what he's said he either has a leak in the line going to the bottom port of the wastegate, a leak in the diaphragm of the wastegate, or a poorly designed manifold that is simply creeping.
  4. #24
    Quote Originally Posted by Brezno View Post
    Changed the pins but still creeping...
    After installing a second 44mm wg the problem was solved. Now i hold the boost until limiter.
  5. #25
    Jan 2014
    Holy shit that's brave!
  6. #26
    How is she holding up?
