Results 1 to 10 of 26
Thread: Low Boost Problem
    Explains why he has boost creep problems? Or just explains how it's setup? Based on what he's said he either has a leak in the line going to the bottom port of the wastegate, a leak in the diaphragm of the wastegate, or a poorly designed manifold that is simply creeping.
    Quote Originally Posted by Brezno View Post
    Changed the pins but still creeping...
    After installing a second 44mm wg the problem was solved. Now i hold the boost until limiter.
