As a start, you should never Tee your wastegate and BOV. They should have their own vacuum sources.
Follow this diagram when you have a boost controller
Definitely a creep-able manifold. Seems that this isn't the issue though. Just because it looks like it can creep doesn't mean that's why. Ensure that the vac line isn't kinked and is big enough and strong enough. There are many cases where poor vacuum lines end up collapsing, typically when things are hot. Also, as a rule of thumb, make sure to zip-tie your vacuum line connections. Slip-fit barb fittings alone don't cut it.
