Results 1 to 10 of 26
Thread: Low Boost Problem
    the OP never specified what all he had or has done to the gate so it explains everything.
    Explains why he has boost creep problems? Or just explains how it's setup? Based on what he's said he either has a leak in the line going to the bottom port of the wastegate, a leak in the diaphragm of the wastegate, or a poorly designed manifold that is simply creeping.
    Quote Originally Posted by Brezno View Post
    Changed the pins but still creeping...
    After installing a second 44mm wg the problem was solved. Now i hold the boost until limiter.
