I'm running the Quaife LSD. I couldn't imagine being boosted and not having LSD. Hell when I was N/A and installed the LSD it was my best upgrade. Still is...
That's one thing I regret when i boosted my S, not getting an LSD. I'm thinking that I'll start to look for an SiR tranny and put an LSD in at that time.
Whats everyone running for LSDs?
My Si came with LSDBut I honestly couldn't imagine driving it without it. ESPECIALLY boosted. As for LSD brands, I have always heard good things about Quaife, and the Torsen LSD is big among the miata turbo guys. That's my
yea quaife ftw. ill be adding one here pretty soon
Yea? Why when your stock LSD is awesome?
Do you find the Si LSD suffice? I readon crsx that the stock Si LSD can't handle boost.
stock lsd isnt awesome, its alright for being stock, but not really even comparable to a quaife
Running the Quaife myself and I really like it .The best price I found was from Cor Sports .When doing a Quaife you'll need a few other items .The Two Diff bearings , and a speedometer gear all can be re used but I would and did replace all three as I would not have felt comfortable re using them .Also you'll need some honda bond or other good sealant .I have an ep3 transmission and for that trans at least maybe some other's as well you need longer bolts for the ring gear from an 06+ civic si the stock FD bolts in an ep3 trans are shorter and won't thread all the way thru the quaife
Hmm, I haven't had a problem with mine, and I haven't heard anyone on 8th having a problem with theirs. My tuner (soxfan143) has his oem LSD afaik. He's in the high 400whp range too. Str8JDM has his oem LSD and has no problems either, 5857bb turbo, 517whp.
