Results 21 to 30 of 72
Thread: My06_types build thread...Finally getting somewhere....
Threaded View
    Newbie My06_types's Avatar
    Apr 2014
    Here is my new build for this past winter/spring. Everything done on this build was done by me and done in the confines of my 2 car garage.
    Wish I had more friends and people around to help with the build or answer questions but I don't... which I why I join these pages to ask any questions I can't find.
    Anywho... on with the pictures. Let me know what you guys think.. not quite finished yet..
    Block
    K20z1 Block
    JE Pistons 86mm 10:1
    Manley Turbo Tuff Rods
    ARP Headstuds
    OEM 86mm Headgasket
    ACL Race rod bearings
    Oem main and thrust bearings
    Hybrid Racing Timing Chain tensioner
    New oem timing chain
    Head
    K20z1 Head
    Supertech std Valves
    Supertech Dual Valve Springs
    Supertech Valve Seats
    Supertech Ti Retainers
    Supertech bronze valve guides
    Multiangle Valve Job
    Transmission...
    Not much as of now.
    Stage4 CC clutch
    K-tuned race shifter
    K-tuned race shifter cables
    Turbo Setup
    Full race twin scroll efr kit
    Borg Warner EFR 8374 dbb Turbo
    Tial 60mm Wastegates
    Tial Blow Off Valve if I use it...
    Fuel System
    Hybrid racing Fuel Rail
    Walbro 255 Intank Pump
    Integrated engineering 2.3L dual pump sump
    Dual bosch 044 fuel pumps
    8AN Feed
    6AN Return
    Deutsch works1000cc Injectors
    HR Fuel Pressure Regulator
    HR Fuel Pressure Gauge
    Aeromotive inline fuel filter
    Other
    wireworx stage 3 Engine Harness
    Shaved RBC Intake Manifold
    Hybrid racing 70mm Throttle Body
    Innovative 75A Motor Mounts
    Hondata 4-Bar MAP Sensor
    Hondata Boost Control Solenoid
    K-Tuned Billet TPS
    BWR oil sandwich Adapter
    Electronic Power Steering
    Relocated Fuse Box to pass air bag
    Relocated Battery to hatch
    Engine bay shaved and tucked by me
    K-Tuned Pulley Kit
    Interior
    AEM Wideband UEGO Gauge
    AEM Digital Oil Pressure Gauge
    AEM Digital Boost Gauge
    Steering Wheel
    Steering Hub
    Record seats
    Suspension/Wheels & Tires
    Buddy Club N+ Coilovers
    new oem front control arm buahinga
    17 x 9+30 rota torques
    245/50/17
    Exterior
    ASPEC Front Lip
    ASPEC Rear Lip
    ASPEC Sideskirts
    ASPEC Wing
    Engine Bay welded, shaved, and tucked...All by me!
    Hand formed all the sheet metal and welded her up!!
