Results 1 to 10 of 20
Thread: Acura EL JRSC M62 Build
Threaded View
  1. #15
    Junior Member K24_Acura_EL's Avatar
    Oct 2013
    East coast Canada
    The latest new on my build is that i spun a rod bearing last month . So before i put the car away for storage for this winter , i am taking the motor out and going to rebuild it and rebuild it to run the JRSC in mind. I am looking at a putting in better rods and pistons in the new block to make some more power and change my TSX exhaust cam to the Si exhaust cams.
    Any other suggestion ?? i would like to make 350 hp with my setup if i can and i am looking for the support bracket that bolts under the manifold of the M62 to the block of the motor.
