Nice build. Id toss that tsx exhaust cam though- source a k20a2/z1/z3 replacement. The setup you have now is a good NA setup but that big exhaust cam will bleed off more boost than you can provide. MercRacing makes some awesome stuff- his tensioner would certainly do the trick. Another cost effective method would be to pick up the 06 civic si tensioner bracket from supercharger.com. The bracket effectively moves your oem autotensioner closer to the SC snout for better belt wrap and tension. I use it on my setup now with no hassles.
