Page 19 of 20 FirstFirst ... 919 ... LastLast
Results 181 to 190 of 200
Thread: 420Coupes R18 241 whp / 231 wtq @ 7.6 lbs
  1. #181
    Junior Member 420Coupe's Avatar
    So turbo smoking and I'm at half oil, any ideas what this can be besides blown seals ?
    Still building boost it was after driving pretty hard temps where normal about half way. Now when I stopped I noticed it smoking but no leaks and it's the hot side smoking not cold side? I'm thinking I'm low on oil and it's hitting to high a temp yet the temp gauge isn't reading high
  2. #182
    Enola, PA
    The hot side is what actually burns oil, Just the one side can blow, you might not have any oil in the charge pipes. If you pull your downpipe if you see burnt oil running down inside of it then its a pretty damn clear indication.
  3. #183
    Re: 420Coupes R18 241 whp / 231 wtq @ 7.6 lbs
    On my 2chainz....TRUUU
  4. #184
    It's the seals at the bottom of the turbo near the return it leaks but very little amount. It was smoking cause blanket was soaking it up and smoking. Stopped as soon as I removed the blanket. Still leaking but ~300 miles and dipstick hadn't moved down. So it's barely dripping but still dripping need to get it rebuilt or new seals rather.
  5. #185
    UPDATE****
    Car is currently at Perky Performance in Gransbury, TX. Taking this bitch to the next level only to find out NEVER got custom valves, still have stock valves inside, fucking base fuel press 20 psi under what it is stock, cracked bowl for cyl 1 in the head, barely any work was done to the HEAD.. the list goes on. Having Endyn see how much they can pull out of the head definitely excited for results. Upgraded fuel pump to the 400 lph Walbro.
    ONLY Good news i had was that i didnt blow my turbo!! just shitty made oil return lines once again thanks to the shitbags over at JOTECH Kissimmee not the REAL BAWLERS IN TX.
    Also have a New toy the K23 Acura RDX SH-AWD shits fun cant wait to get hands on in tuning and tweaking!
  6. #186
    Dang sucks a shop did that kind of work.
  7. #187
    Wow. This is serious man, and congrats post pics of the RDX! Toss a BoostedK20 decal in dat bish u can start the club!
    Too late totaled the RDX back in November
  9. #189
    Quote Originally Posted by 420Coupe View Post
    What are you driving now?
    And we're just starting! we had a successful start to testing on the ‪‎VitTuned‬ Honda Civic R18 running our custom VitTuned MoTec‬ ‪M150‬ firmware package. The fuel system couldn't keep up and I had to cut the testing short, but everything went very smooth otherwise -- made 410hp & 330tq on 22psi of boost using an old PTE 5757 turbocharger (with a 2.5" downpipe at that).
    The MoTeC firmware package we've developed brings a lot to what has been an otherwise neglected platform -- anti lag, closed loop boost control, boost by gear, closed loop lambda control w/ an LSU 4.9 wideband sensor (accurate even for full time closed loop in boost!), launch control, traction control, flat foot shift, rolling antilag... the list of features just goes on! We'll be demoing some of the features after we get the fuel system upgraded to handle big power on this platform.
    When an R18 sounds more savage than your K series.
    View: https://youtu.be/MapKOuxBM5k
