What filter are you using?
Well as most you may know im building my fuel setup here shortly and need yall's help. I just ordered the K-tuned high flow fuel filter from sean that gave me a great deal no one could beat in the market. Now my dilema here is what "fancy" mounting bracket can i use to mount this beautiful pc. Now have in mind i will be mounting it some where in the bay not under the car, so the bracket has to be presentable and not "ghetto". Per recommendation my fuel filter should be as close as possible to the rail, but not on it. So shoot me ideas, links to the product where i may purchase it.
Thanks for your help in advance.![]()
cough cough the ktuned inline fuel filter
the small one
8AN size filter measures 1.25" in diameter and 3.5" in length
Ok. I'll look around. They make billet mounts for pumps I'm sure they'd have something for a filter if it's similar in size
yea i seen those and nothing to fit the desired size.
but yea lmk brah
What type of filter element? Is it rated for e85? With that small a filter you probably dont need a mounting bracket at all- the fuel line will hold it up in place because the filter is so light. My aeromotive is just ziptied to the brake line.
Yes its a e85 compatible filter mesh screen and a 30 micron
this looks promising
