Results 1 to 10 of 11
Thread: DIY - Valve Lash
    DIY - Valve Lash
    Ok so while my son is sleeping I figured I'd make a diy on this. I've seen a lot of people take this and blow it up into this huge ordeal. But it doesn't have to be that way. So I'm here sharing my tip on how I've been doing this for years on my Hondas.
    Tools needed:
    Valve lash specs (mine are .30mm intake and .30mm exhaust) on kelford C's
    10mm wrench or socket (I prefer a wrench)
    Flat blade screw driver
    Set of feeler gauges
    19mm socket and 3/8" ratchet
    I used a straight set of feelers and just need to tip to about a 45* angle.
    So first things first remove the valve cover. (my motor didn't have it on so that is not in here.)
    1) place the motor at TDC (top dead center) using your 19mm and ratchet on the crank pulley
    This is what your cam gears should look like.
    At this stage you can go ahead and adjust both intake and exhaust valves. Break loose the jam nut and loosen the screw. Slide your feeler in there abs begin to tighten the screw till it starts to drag against the false while moving. Lock that in place. It's easier to do with the wrench because you can hold the set screw in place and it won't move on you.
    I found it easier to adjust the intake valves like this
    And exhaust valves like this
    Now notice how the cam lobes are in this pic at #1 TDC
    Notice they are up and pointing towards each other. This ensures the valves should be fully seated.
    Now you rotate till you see a set of lobes get to the same position
    Which is cyl 3
    Cam gears well look like so...
    Adjust your cake last on cyl 3 now.
    Once done rotate the crank till cylinder 4 lobes hit the position
    Cam gears will look like this...
    Adjust and let's move on.
    Cyl 2 is next...
    Cam gears line up like this...
    Adjust and lock your jam nuts and Boom your ready to Rock.
    Don't fret over this simple task it's really easy one you get the hang of it. Should take you ~15-25min.
    I'm unsure of your specific valve lash specs so please have those ready when you go to do your own motor. The specs I have are for my application only (unless you have kelford C's like I do)
    Very nice had a DIY in mind. U beat me to it.
    Repped
    Repped
    Thanks. Figured I've been slacking because I prefer to take a picture of visible progress not step by step. This was simple enough to do and not spend all night writing up.
    Moderator ryaano18's Avatar
    Mar 2013
    Houston
    Repped
    Looks like [MENTION=56]PetefromtheStreets[/MENTION] is coming for my one upper title!
    But seriously good diy!
    Btw u might want to add that the specified specs will be on the hood for each vehicle.
    What a coincidence hugh ryan, both u guys had the valve lash done the same day.
    Senior Member
    Good job Pete
    Senior Member Frostydc5's Avatar
    Jul 2013
    NOVA
    good write up man, its such a simple task and I see the same thing, people blow it out of proportion like its really complicated or soemthing
    Repped
    You can do the video version! I'll post it on the YouTube page as well!
    Quote Originally Posted by ryaano18 View Post
    #mroneupper I should make that and a Trollphy up for grabs!
    Quote Originally Posted by Frostydc5 View Post
    Agreed!
    Great article man
