Results 1 to 10 of 20
Thread: Ep3 fuel quick fitting
    Jan 2014
    Hi guys.
    I need an adaptor for connecting my oem fuel fitting to an AN6 teflon fuel hose,
    I have all the fittings aside from the quick connect to an6 to the hardline on the bulkhead, it seems to be smaller than the 5/16" used on the fuel rail connectors
    A good guess would be that it's 6mm/ 1/4". Yet I'm really struggle to find one. Anybody else done this
    [MENTION=1040]Jonezy[/MENTION] let's get these guys to chime in
    [MENTION=28]Spaz[/MENTION] [MENTION=56]PetefromtheStreets[/MENTION] [MENTION=185]aLmk[/MENTION] [MENTION=40]monjarassi[/MENTION] [MENTION=2]Si Speed 317[/MENTION] [MENTION=193]Xander[/MENTION] [MENTION=775]Poita[/MENTION] [MENTION=1029]Shanket[/MENTION]
    That's a tough one I been looking
    Actually, our BoostedK20 Si used the stock fuel fitting with the -6 K-Tuned rail. We used a Hybrid Racing adapter piece. Check that out, let me know if that's what you're looking for. http://www.hybrid-racing.com/store/engine/fuel-fittings [MENTION=1040]Jonezy[/MENTION]
    Dec 2012
    Brazil
    Have you tried that ?
    http://www.summitracing.com/parts/RUS-641303
    Fits perfectly on the FA5! Not sure about the EP3 though...
    Jan 2014
    Corpus Christi TX
    32
    i just did a -6an or -8an from firewall to fuel rail
    I just used a bunch of clamps cause back when I changed rails no one knew of a quick release fitting. But now you can buy them
    Where exactly do you need this fitting to go? To connect the oem hardline to the bulkhead fitting at the cage?
    Jan 2014
    [MENTION=28]Spaz[/MENTION] - that looks the size pal. I measured it with caliper as 6.1mm I think, which is near as dammit 1/4".
    Thanks for the input. Just got to find one this side of the pond!
    Jan 2014
    This is zoomed out to show the general area, just about 5" behind the collector on the manifold is where the pipes are on the firewall
    This is a closer pic, although iphone doesn't like taking the pic.
    Not the best pics, but hopefully you can see where I mean
