Another update**
Alright so here's an update. After having fuel pressure issues that came out of nowhere and with the help of some legit OG's I got my ride back in the road and finishing my first e-tune! So I was driving along no big deal filled up on has and my ride wouldn't start. Hmmmm strange after a few cranks it turned over. The I threw an evap leak cel. Okay tightened the gas cap and cleared the code. It never came back. But as I was getting ready to do a run for my tune as soon as I put in 3rd and wot the car started to surge after 3 g's. My tuner thought maybe the injectors, although they're brand new or some how I am loosing fuel pressure. But at idle everything worked fine, the pressure check showed the pressure was there. Hmmmmmm....big thanks to monjarassi! Huge thanks. I hit him up and he was quick on the reply and quick to help too. So the symptoms were surges at higher rpms, and the car would not turn over when it was hot. After hours of troubleshooting and scouring the net, monjarassi put me on to Brian at speed lab.net. This dude knows his stuff. Straight genius if you ax me. Any ways he looked at my datalog, and within a very short time (this dude got back to me immediately after I contacted him!) LEGiT.. Brian hit me back with only a few possible scenarios and it made sense. Bad fuel pump(but mine is brand new), bad in tank regulator(never thought of that), or a pin hole in the fuel line in the tank which would explain why it wouldn't start when hot. So I changed back to my stock pump, same problem. Whew at least it wasn't the new fuel pump, my next step was to change the fuel lines and check the regulator. (Brian said he'd seen the regulator be the culprit more times then not). And when I pulled the pump. Boo ya the regulator wasn't seated right. It looked like pressure had blown it out. So I put back in right after inspecting the o ring and replacing I put a zip tie to hold it for extra reinforcement. And now my boosted ep3 is back on the road finishing up my tune. Whoa after hours and days of trouble shooting this one little thing I overlooked cause some headaches. But mahalos to monjarassi and Brian at speedlab.net. Brian narrowed it down for me in just a couple hours! Now he beast is running nice!
