Newbie
IMT High Speed Idler Pulley
It is well known that the CT and JR smooth idlers are prone to failure. We analyzed failed pulleys and designed a much improved direct replacement. Utilizing FEA software we designed a precision machined austenitic stainless steel housing as opposed to the aluminum or plastic housings currently available. The IMT pulley also includes propriety dual high speed sealed ball bearings. And yes, they are replaceable if the need arises.
Tags for this Thread
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
