Results 101 to 110 of 302
Thread: Suki build
Threaded View
    Senior Member Shanket's Avatar
    Jan 2014
    Corpus Christi TX
    Age
    33
    Suki build
    Updated mod list
    Build 2006 Acura Rsx Type-S
    Tuned By Comp JLT tuning / D3 Performance & Engineering
    Engine:
    89355k start new block
    Start 56k on k20z1 head- Now Zero
    98k chassis
    422hp on 9 psi –e85
    Engine
    87.5mm Weisco piston and rings
    88mm Cometic Head Gasket
    Arp Head Studs
    Bore .50
    Brain Crower H -Beam rods with Arp 2000 rod bolts
    Built bottom end stage 3 k24a4 from Kmod Performance
    Built k20z1
    Compression is 10:5:1
    Hybrid Racing Tensioner
    K24 Chain
    K20A2 Oil Pump
    K20a2 Oil Pan
    Stock sleeves
    Stock crank
    Head K20z1
    BC Stage 2 Cams NA/ Turbo
    Ferrea Super Alloy Valves
    Ferrea Bronze Guides
    Ferrea Dual springs
    Ferrea Seat Locator
    Ferrea Valve Seals
    Oem Rockers
    Standard Size
    Valve Job
    Turbo Setup
    2.75 inch intercooler piping
    45mm Turbo smart waste gate
    AFI Turbo Side winder Manifold- Coated White Lighting
    Dump tube- Coated white Lighting –custom
    Garrett 3071 60mm trim
    Spearco intercooler 18.48 x 9 x 3.5
    Tial 50mm bov in purple
    Exhaust setup
    .82ar Turbo exhaust housing
    3-inch turbo back exhaust- Coated White Lighting
    3-inch Vibrant Resonator
    3-inch Vibrant Street Power muffler
    QTP electric cut out
    Vibrant Muffler tpv
    Vibrant Resonator
    ENGINE BAY
    Dual core Koyo radiator
    Ep3 A/C line
    Ktuned Oil Dipstick
    Hasport 88a race series Motor mounts
    RBC intake manifold powder coated in black
    Hybrid racing 70mm throttle body,
    Hondata intake manifold gasket.
    Hondata 4 bar map sensor
    Koyo radiator cap
    Ktuned Oil Dipstick
    Ktuned tps sensor,
    Purple Valve cover,
    Mac Boost Senolid 3port
    Nrg Spark Plugs 8
    Turbo Guard electric blue turbo screen
    Fuel
    1000cc injector dynamics,
    2 Walbro 485 fuel pumps
    8an Feed Russell Pro flex Hose black
    6an Return Russell Pro Flex hose black
    Aero motive 340 fuel pump,
    Full Blown inline filter 40 microns
    Hybrid racing fuel rail,
    Hybrid racing fuel pressure regulator gauge,
    Ktuned Fuel Pressure Regulator
    Radium Engineering Multi-pump Surge tank
    Radium Engineering 2 Relays
    Transmission
    K20z1
    Custom Clutch Stop
    Ktuned Billet arm
    Ktuned Shifter cables race spec
    Hydraulic Throw out bearing
    JTC Custom shifter
    PPG 1-4th helical gearset and mainshaft
    Oem Final Drive 4.7
    Quiafe Lsd
    Strut king Brushings
    Tilton Twin Disc clutch 910tq
    Tilton Clutch Master Cylinder ¾ kit
    Interior/ Exterior
    350mm Nardi Steering wheel
    Aspec Rear Lip
    Aspec Side skirts
    Bride custom Shift boot
    Blox Racing weighted shift knob / Js racing knob
    Black interior
    C-West Front Bumper
    C-West Carbon Canards
    First Max Racing Vis Racing Carbon fiber hood
    Jdm Type R taillights
    J’s rep Rear diffuser
    J’s Racing Wing 1600mm -225mm risers
    Nrg Harness bar
    Nrg short hub
    Recaro profi seats with Recaro side mounts
    Sti Gauge pod
    Takata 4 pt harnesses
    Works gcf quick release
    Vis Racing Carbon Fiber trunk
    Headlights Retrofit
    5500k Low Beam Morimoto Kit
    5500k High Beam Morimoto Kit
    E46 shrouds
    Mini h1 projectors high beam quad headlights
    Red demon eyes
    Tsx clear projectors
    Brakes
    Deleted ABS
    EM2 Mini valve
    Front-
    Rotora Slotted rotors oversized
    Rotora 4 piston Calipers Red
    Rear-
    EBC USR slotted Rotors
    Project MU Brake pads B force
    Suspension
    BC-Br Racing Coilovers 10k, 12k
    Cusco B- pillar bar
    Js racing rear c pillar bar
    Nuespeed Front Strut bar
    Nuespeed Tie bar
    Oem-Tie rods
    Skunk 2 Lower control arms
    SPC Camber kit
    Prelude Ball Joints
    Wheels and Tires
    Project Kics 5mm with studs
    Updated wheels: 17x8.5+30 Gram lights 57c
    Nitto Nt05 225/45/17
    Updated: RPF1 17x9+22
    With Toyo 255/40/17 front
    Rear 245/40/17
    Electronics
    App Radio 2
    AEM Failsafe Gauge
    Custom sub Box
    Excalibur Remote Start LCD
    Fusion Green RCA cables
    Haltech ECU
    HKS Turbo Timer type 1
    Interstate battery trunk mounted custom bracket
    Omega Bypass
    Rockford Fosgate P2 Sub
    SSL 1500watt amp
    Tanabe oil pressure
    Zeitronix flex fuel kit with gauge
