Page 2 of 2 FirstFirst ... 2
Results 11 to 15 of 15
Thread: DIY: putting the engine on engine stand.
  1. #11
    Moderator ryaano18's Avatar
    Mar 2013
    Houston
    Damn. I wouldn't think about using anything short enough for that. Good way to ruin a block.
    Your admin eyes are very good Lmao. Thanks man!
    Lmao. Suuuuuuuuuure you don't. I'll keep my mouth shut for a "ryaano" harness.
    so blackmail is what this had to come too lol
  2. #12
  3. #13
    Quote Originally Posted by ryaano18 View Post
    Only if it works. Lol
  4. #14
    When I did mine I had to buy one bolt as I was able to use the 2 long transmission bolts, but didn't feel as though enough thread from the regular transmission bolts was going into the block because my bracket for my engine stand has pretty long slots if that makes sense. For the long bolts I just had to use a stack of washers as they otherwise would be too long.
  5. #15
    Good call. Stripped threads are no good. Better off with long bolts and washers than short bolts and a stripped block!
