Page 57 of 57 FirstFirst ... 74757
Results 561 to 565 of 565
Thread: *Turbo Chat Thread*
  1. #561
    Quote Originally Posted by beppe View Post
    All finished.. just few bits need tidying up.. battery needs relocating to the back, no power boost spikes.. smooth power like SC to redline.. helps my traction... lets see how much that turbo can take before it shits its self. lol
    had to reduce spark plug gap as high compression think spark was blowing out.. now is fine.. didnt do it on dyno.. just under load..
    What did you bring the gap to? And what were you running as for gap on the dyno?
  2. #562
    Just a heads up that happened to me.
    I was @ .22 and had to bring er down to .16
  3. #563
    Think I'm at .018"
  4. #564
    Think I'm at .018"
    Our Si is at the same .018 gapping. Bkr9eix plugs.
  5. #565
    Dec 2013
    i put mine down to from 0.9mm to 0.6mm that's around .022"
    was getting knock in high gears near redline.. think gapping has solved it
