Page 9 of 57 FirstFirst ... 919 ... LastLast
Results 81 to 90 of 565
Thread: *Turbo Chat Thread*
  1. #81
    its a db fab manifold. Few others i have seen had one and it didnt creep this bad. i might venture into another gate, or an AFI manifold.
    i even had the wastegate ported out larger.
  2. #82
    Last year it would hold 17psi but that was with a 2 1/4 exaust creating a lot of back pressure.
  3. #83
    Wait, it's creeping 20psi or creeping to 20psi? Because there's a big difference, lol. I can see why it would creep though.
    BoostedK20 Sponsor Rbsjnh's Avatar
    May 2012
    Autofair Honda of course
    The mani is probably the culprit. I will start a thread for the jdl design stuff threthread
    Support Innovation, Not Imitation
  5. #85
    well today it seemed to work better. the tuner worked the boost controller a little more, and we got to add some timing to it along with the meth. it stays in the 15psi range from 4900-7000, then creeps to 17 by 8000... then i was just scared lol
  7. #87
    if all else fails, ill sell it and buy a new manifold, or buy another wastegate to have it welded on the bottom
  8. #88
    I would save the money of buying another gate and go with a well known and r&d'd manifold like AFI or FULL-RACE. I've seen a lot of people try and modify the mani's with little success.
  9. #89
    Got mag tuned today. Couldn't figure out why I was over boosting even with the settings on the hondata boost controller on the lowest. was seeing 18lbs when i wanted to get tuned to 10-12
    so we just turned off the boost control and tuned off my WG spring.
    Any anys why it wasnt working?
    All vac line are hooked up correctly.
  10. #90
    Well whats going on with the car ? Is it fixed ? you buy a different manifold ? wg ?
