Why not use honda bond instead of teflon tape on those NPT threads?
woohoo a couple parts came in today
Thanks to kseriesparts.com I got my new oil sandwich for my gauge install
http://i918.photobucket.com/albums/a...psgvvwa9mm.jpg
http://i918.photobucket.com/albums/a...ps1aucyxko.jpg
And the first package arrived from JHPUSA
http://i918.photobucket.com/albums/a...psd9ghxlts.jpg
Rest should be here tomorrow
ok plenty of updates.. loading photos now.
So I finally am starting to get the car back on the road. So I have a bunch of work ahead of me. So one of the items on my list was swap out my sideskirts to the new one.. but I must admit I am COMPLETELY DISSAPOINTED with the new TopOne products.
Anyways started taking off my sidekskirts
http://i918.photobucket.com/albums/a...psayrszmut.jpg
http://i918.photobucket.com/albums/a...psjshhsxyv.jpg
unbolting the old TopOne add on skirts
http://i918.photobucket.com/albums/a...pslbq7hlwu.jpg
Here is the old verse the new.. the old one was HUGE compared to the new one. It was wider and more aggressive and the winglet was twice the size..
http://i918.photobucket.com/albums/a...psriticmz8.jpg
winglet comparison
http://i918.photobucket.com/albums/a...ps9hwdwt5f.jpg
None of the preholed bolt holes match up.. so I clamped them together and redrilled them
http://i918.photobucket.com/albums/a...pst2wvbaok.jpg
http://i918.photobucket.com/albums/a...ps63xsulbw.jpg
http://i918.photobucket.com/albums/a...psdrmzc2e2.jpg
and then reinstalled
http://i918.photobucket.com/albums/a...pswnddgqvf.jpg
http://i918.photobucket.com/albums/a...psgntqb0dk.jpg
Here is a comparison of the old verse new.... not aggressive at all anymore...
http://i918.photobucket.com/albums/a...pslt7kv5x5.jpg
and final look
http://i918.photobucket.com/albums/a...psqtkw7tbh.jpg
http://i918.photobucket.com/albums/a...psvilf1vq1.jpg
http://i918.photobucket.com/albums/a...psq65xso6i.jpg
putting work in i see
so got most my parts in today but realized I forgot to order the damn hub...
http://i918.photobucket.com/albums/a...psvy5i53pd.jpg
NRG quick release
http://i918.photobucket.com/albums/a...psym0i1yaj.jpg
Personal Trophy Edition steering wheel
http://i918.photobucket.com/albums/a...ps4fashkqs.jpg
love it!
http://i918.photobucket.com/albums/a...pstfwnw83g.jpg
http://i918.photobucket.com/albums/a...ps7furjpwa.jpg
http://i918.photobucket.com/albums/a...psmu3y6eya.jpg
so started taking it all apart. Removed the covers
http://i918.photobucket.com/albums/a...pstdzeqidn.jpg
http://i918.photobucket.com/albums/a...psltjg85uk.jpg
removed side pieces to expose bolts and srs
http://i918.photobucket.com/albums/a...pshsyujeyn.jpg
unplugged SRS
http://i918.photobucket.com/albums/a...psbmfq4pjf.jpg
used Torx bit to removed
http://i918.photobucket.com/albums/a...ps1ajthaxj.jpg
pulled airbag out
http://i918.photobucket.com/albums/a...pshzimnpqr.jpg
then used 14mm to remove steering wheel
http://i918.photobucket.com/albums/a...ps4ca6ebb2.jpg
http://i918.photobucket.com/albums/a...psz2cnatmq.jpg
Ok so I was searching around while installing my quick release steering wheel and everyone talked about breaking the clockspring to get it off. I didn't see why everyone struggled I figured it out right away how to take it off without busting it.. So I thought I would share
pull clock spring forward and out
http://i918.photobucket.com/albums/a...psuggzmg8w.jpg
This is the piece we are trying to remove without breaking
http://i918.photobucket.com/albums/a...ps981wmftj.jpg
To do so just release the bottom clip with a flat head screw driver
http://i918.photobucket.com/albums/a...psxlzxdqge.jpg
Then the harder part everyone gets stuck on.. using a flat head push down here
http://i918.photobucket.com/albums/a...psz0stvt7d.jpg
http://i918.photobucket.com/albums/a...ps8x6eqjhx.jpg
As you can see it's just a push tab you need to push down on to release the clip
http://i918.photobucket.com/albums/a...psrfcz4yxt.jpg
and now you've successfully removed the clock spring without breaking it.
but I forgot to buy the hub so I need to wait till that comes in the mail
ok also pulled out my AC vent
http://i918.photobucket.com/albums/a...ps80mvnioo.jpg
finally swap out my home made black for a black vent
http://i918.photobucket.com/albums/a...psqeuviesn.jpg
them pulled out my cluster so I could change out the wiring harness for my AEM boost gauge
http://i918.photobucket.com/albums/a...ps5blhjdmb.jpg
http://i918.photobucket.com/albums/a...pskfpwsngy.jpg
old verse new... AEM things my harness went bad. So hopefully this fixes my boost issue
http://i918.photobucket.com/albums/a...ps3dum4bpc.jpg
rewiring it back up
http://i918.photobucket.com/albums/a...pssdsmr64s.jpg
start putting back together
http://i918.photobucket.com/albums/a...psh3flvnxd.jpg
done
http://i918.photobucket.com/albums/a...psjdeawfzh.jpg
here you go!
Redid the ghetto oil feed setup. This is what I removed compared to the new filter sandwich
http://i918.photobucket.com/albums/a...psl5z1bwrr.jpg
this is what I will go with
http://i918.photobucket.com/albums/a...psgdvxbct2.jpg
instead of thread tape I am going with HondaBond
http://i918.photobucket.com/albums/a...psy2s9x3ld.jpg
put all the fittings on
http://i918.photobucket.com/albums/a...psh3atppue.jpg
and final install. So much cleaner! Glad I went this route
http://i918.photobucket.com/albums/a...psxmllmftk.jpg
