Hey Andrew I'm far to lazy to scroll through your entire thread , but what did you use to space your VSS with your 5speed trans? My VSS is going nuts I thinks it's to far spaced.
I see, I used 2 washers maybe I'll take one off!!!
Thanks man
Yeah I enter the new ratios and FD but my speedo is acting a fool, vit said fix my VSS lol
Ya I just swapped to a 4.3 FD, but my speedo was still inaccurate even after changing the ratio in flashpro, Vit had to adjust my speedo by 8% which is another setting in flashpro. But my speedo never worked weird, just read a little lower than I was actually going. I would try one washer and see how that works for you.
I'm going to measure them today when I get home, when I installed them I felt it was really close to touching in there, but I'll try to get a thicker fender washer and just use 1
Yeah trying today , I did a second gear pull and it went to 80 then to 44 then to 78 when I let off the throttle lol
