What does the inside of a K series look like
Some of you may not know what the inside of a K series engine looks like here are a few pics with some brief comments of a bone stock k 20Z1 short block tear down
Removing the rod bolts to pull pistons and rods
http://i540.photobucket.com/albums/g...d/IMAG0926.jpg
Pistons and rods on the table
http://i540.photobucket.com/albums/g...d/IMAG0936.jpg
pulling the center main bolts
http://i540.photobucket.com/albums/g...d/IMAG0933.jpg
a view from the bottom of the block where the oil pan normally covers
http://i540.photobucket.com/albums/g...d/IMAG0937.jpg
After removing the lower girdle and lifting the crank and bearings out
http://i540.photobucket.com/albums/g...d/IMAG0942.jpg
Lower Girdle
http://i540.photobucket.com/albums/g...d/IMAG0961.jpg
Lower Girdle and Crankshaft
http://i540.photobucket.com/albums/g...d/IMAG0946.jpg
Bare Block you can see where the oil squirters are normally located they are removed in this pic
http://i540.photobucket.com/albums/g...d/IMAG0962.jpg
Pistons , Rods , Girdle , Crank ,and Block
http://i540.photobucket.com/albums/g...d/IMAG0939.jpg
View from the top of the Bore where the Cylinder head bolts to
http://i540.photobucket.com/albums/g...d/IMAG0969.jpg
