Nice kinda of what i'm looking for. did you just add washer to push the mounting points out?
http://i181.photobucket.com/albums/x...ps3bd9f28d.jpg
http://i181.photobucket.com/albums/x...ps1fbbc90f.jpg
http://i181.photobucket.com/albums/x...ps831105cf.jpg
http://i181.photobucket.com/albums/x...ps49379c10.jpg
http://i181.photobucket.com/albums/x...psd12e8d73.jpg
http://i181.photobucket.com/albums/x...ps1562003f.jpg
http://i181.photobucket.com/albums/x...ps83464ff5.jpg
http://i181.photobucket.com/albums/x...ps24e5b23c.jpg
http://i181.photobucket.com/albums/x...ps59ba224e.jpg
http://i181.photobucket.com/albums/x...pscad5b5dd.jpg
I still need to fine tune the shaping. I did mount them to the car tonight and added my 15mm spacers in the front. The vent gap is at 5mm right now. Im unsure it i want to push that out to 10mm.
http://i181.photobucket.com/albums/x...psd544df63.jpg
http://i181.photobucket.com/albums/x...ps433f22a0.jpg
Without 15mm spacers.
http://i181.photobucket.com/albums/x...psffc6831a.jpg
With spacers.
http://i181.photobucket.com/albums/x...ps75c4167b.jpg
http://i181.photobucket.com/albums/x...ps4ef4a908.jpg
http://i181.photobucket.com/albums/x...ps8257c3e1.jpg
The wheel set up i have on there now is 16x6.5 +45 with 15mm spacers on them.
youd really need to test out a 17x9+35 and see what good
Specs: 17x8 +35 17x9 +38
http://i203.photobucket.com/albums/a...psba9a18a0.jpg
http://i203.photobucket.com/albums/a...ps7fb811d2.jpg
Started to work on a headlight intake with the extra set of CTR headlights i own
http://i.imgur.com/zUYVHUV.jpg?1
http://i.imgur.com/VGGi0Fw.jpg
http://i.imgur.com/AOmiHqQ.jpg
http://i.imgur.com/J7NhdWi.jpg
http://i.imgur.com/qCBnqCF.jpg
http://i.imgur.com/JwgAkXO.jpg
Battery disconnect arrived
http://i.imgur.com/fJRXKWv.jpg
http://i.imgur.com/mLZZvRc.jpg
http://i.imgur.com/ShbyQT7.jpg
-Gauges in
-Battery disconnect mounted where the AC controls were
-Circuit Hero shift knob
-S2000 push start
-Custom brushed aluminium placards
http://i.imgur.com/rCCL7L7.jpg
CF fenders and hood back on
http://i.imgur.com/NKf9XtF.jpg
http://i.imgur.com/3sK5BRd.jpg
http://i.imgur.com/DLqhz5Y.jpg
http://i.imgur.com/YGMmnow.jpg
http://i.imgur.com/IxQwz3j.jpg
i got some 42"x 24" .10 lexan sheets. I used the other panel as a stenciling tool. I cut the holes for the strap and door release. I'm working on getting Takata tagged door release pulls to keep the Takata theme going. The black is just a mock up. I'll be covering it in matte black vinyl. Also the door still needs to be shaved down so the sheet fits flush. Here is some mock up pictures.
http://i.imgur.com/AdCTRWh.jpg
http://i.imgur.com/ywnK2wm.jpg
http://i.imgur.com/cunyfa1.jpg
I received my Ohlins DFV Coilovers today.
http://i.imgur.com/FDezSzE.jpg
Before ordering them I did some research on them. The dual flow value is an outstanding design for road and track. The valves open, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tires to stay in contact with the road at all times.
http://www.roadandtrackbyohlins.com/...t_dfv_fig4.jpg
They have 25 clicks of rebound adjustment, and inverted front strut design. I went with the adjustable camber plates for the front. The spring rates from them are: Front = 450lb/in & Rear 560lb/in.
I'm going to replace my front axles before i throw these on.
so jelly of the wheels!!
And damn Ohlins coilovers?! $$$ baller
monjarassi still wants those wheels!!
Got myself into this mess. All the panels are out besides the driver door. I still need to lose the headliner. I got pressed on time and had to throw the driver seat back in to get to work in the morning. I still need to tuck and rewire a lot but it was good progress this weekend. Its suppose to be in the 70s this week. I'll trying and get some more done during the week.
http://i.imgur.com/R3Bt7z8.jpg
http://i.imgur.com/t1FcRLQ.jpg
I'm trying to feed the addiction of working on the car without spending money. I still new axles and i plan on get M&M racing tie rods, then ill throw the ohlins in.
http://i.imgur.com/qwpTqMp.jpg
http://i.imgur.com/uB9dKVo.jpg
http://i.imgur.com/TUvolxS.jpg
http://i.imgur.com/thOo9JH.jpg
Picked up a harness bar, once it shows up i'll be sending all the bar to get powercoated white
