Re: Help with Rotrex lack of boost
Ended up finally fixing my IAT sensor which had to do with wiring and not the sensor itself. Didn't help my problem, ended up finding out if was an injector not firing. Fixed that and the car is sounding like a Honda again thank god. Shortening my charge piping tommorow and seeing if we can get over 9psi on the high cams. Crossing my fingers. Makes way more sense why the car sounds like this if its running on 3 cylinders. Hopefully that can help anyone who encounters the dreadful subbie sound
Sent from my iPhone using Tapatalk - now Free
04carboncivic
now Free
Glad to see you got that fixed. I didn't think the IAT would cause a misfire sound. I would pull the fmic and check it for leaks and the same for the rest of the charge piping as well.
If your having trouble with your couplers a little trick is to spray a bit of hairspray on the inside of the couplet and then reinstall. It Will not pop back off or if it does then you sir have just made a great deal of power. (Or your engine mounts are not sturdy enough showing to much movement)
[MENTION=824]SAX JONZ[/MENTION] Please post an informational article on your problem. Please note your initial symptoms, successful methods of problem solving, the solution, and the result. That way, others can search for the issue, find your thread, and BAM fixed. It also allows other people's .02 on the matter, allowing for greater knowledge on the topic for us all. Thanks, and I'm glad it's all figured out!
Has anyone here had the bearings inside a rotrex go bad? I have this horrible sound coming from it now. It still produces boost to what seems like normal, I checked the fluid level and it is the same as when I installed it 2 months ago. I bought this c38-81 used so not sure of its prior maintenance but it sounded and worked just fine for the last two months. I don't even know if these can be sent out to be serviced. Ahh this build is quickly becoming a disaster.
04carboncivic
now Free
[MENTION=56]Adm_rsx[/MENTION]
04carboncivic
now Free
I have not heard of or ever had my bearings go bad before but you can get in touch with TTS Performance and talk to Richard about getting yours looked at If you want.
I would check to make sure the bolts are all tight. Being that they are only tightened to 11-15ft.lbs it's possible they could have come loose.
Thanks for the suggestions. I had the car running and used a flat head as a stethoscope and it hurt my ear when I held it to the power head. The blower doesn't have much if any vibration feeling from loose bolts, even when revved, feels more like a rough movement from within the unit. Sigh, if its cooked I think I may go turbo than purchase a new unit at full price
